Torna indietro   Roboitalia.com - Il primo portale in Italia sulla robotica amatoriale > Robotica di base > Informatica > P. in Assembler
Strumenti discussione Modalitą  visualizzazioe
Vecchio 06-08-2012, 09.25.10
MaryFrą MaryFrą non ĆØ collegato
Residenza: sicilia
Etą : 31
MaryFrą E' per ora ancora un mistero
Predefinito help !!
Good morning. I am a italian student and i'm working with a display in my project. I try this program :
#include "io430.h"
//<msp430f5437A.h>
// LCD Port assignement
#define LCD_DIR P4DIR
#define LCD_OUT P4OUT
// Lcd Pin assignement
#define LCD_PIN_RS BIT4
//#define LCD_PIN_RW BIT7 connesso a GND
#define LCD_PIN_EN BIT5
#define LCD_PIN_D4 BIT0
#define LCD_PIN_D5 BIT1
#define LCD_PIN_D6 BIT2
#define LCD_PIN_D7 BIT3
// Procedure to strobe data to LCD register
void LCDPulseEN(void)
{ // Set Enable active
__delay_cycles(20);
LCD_OUT |= LCD_PIN_EN;
__delay_cycles(20);
// Release Strobe
LCD_OUT &= (~LCD_PIN_EN);
// this send 4 bit of data
void SendNibble(char data)
// Clear all data bit
LCD_OUT &= ~(LCD_PIN_D4|LCD_PIN_D5|LCD_PIN_D6|LCD_PIN_D7);
// Set data bit on port bit
if(data & 0x01)
LCD_OUT |= LCD_PIN_D4;
if(data & 0x02)
LCD_OUT |= LCD_PIN_D5;
if(data & 0x04)
LCD_OUT |= LCD_PIN_D6;
if(data & 0x08)
LCD_OUT |= LCD_PIN_D7;
// Nibble set complete, send to LCD
LCDPulseEN();
__delay_cycles(500);
// Send a byte of data to LCD register
void SendByte(unsigned char data)
SendNibble((data>>4) & 0x0F);
SendNibble((data) & 0x0F);
// send a byte to command register
void SendInstruction(unsigned char data)
// Set Register to command
LCD_OUT &= ~LCD_PIN_RS;
SendByte(data);
__delay_cycles(80000);
void LCDputch(unsigned char data)
// Set Register to data
LCD_OUT |= LCD_PIN_RS;
SendByte(data);
void InitLCD(void)
// clear all bit of LCD control & data Lines
LCD_OUT &= ~(LCD_PIN_EN|LCD_PIN_RS); //|LCD_PIN_RW);
// Set LCD pins to output
LCD_DIR |=(LCD_PIN_EN|LCD_PIN_RS|LCD_PIN_D4|LCD_PIN_D5|LCD _PIN_D6|LCD_PIN_D7); // |LCD_PIN_RW
// wait Powerup
__delay_cycles(100000);
// LCD can be in an unknown state so set to a known state sending 3 times LCD set to 8 bit mode
SendNibble(3);
__delay_cycles(16000); // Wait for init
SendNibble(3);
__delay_cycles(400);
SendNibble(3);
// now is 8 bit, sending 2 set mode to 4 bit (0x2n)
SendNibble(2);
__delay_cycles(800);
// Now set to mode 4 bit 2 line 5x7 char
SendInstruction(0x28);
__delay_cycles(8000);
// Make cursor visible one line set to 0x0c to invisible cursor
SendInstruction(0x0e);//c
// Clear screen
SendInstruction(0x01);
// Increment address mode
SendInstruction(0x06);
// Set write data address to 0
SendInstruction(0x80);
// Set write cursor to Row and Col
void LCDSetPosition(char Row, char Col)
// if row is not 0 add 0x40 (4 line models require adding 0 20 60 40)
if(Row)
Col+=0x40;
SendInstruction(0x80 | Col);
// Clear LCD
void LCDClear(void)
// Lcd cursor to first row first column
void LCDGoToHome(void)
SendInstruction(0x02);
// Shift left mode
void LCDShiftLeft(void)
SendInstruction(0x18);
// Shift right mode
void LCDShiftRight(void)
SendInstruction(0x1C);
// Cursor blinking mode
void LCDBlinkCursor(void)
SendInstruction(0x0F);
// Print a text line to LCD screen
void LCDPrintString(const char * Text)
while (*Text)
LCDputch(*Text++);
void main (void)
// char c;
// int i;
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
InitLCD();
LCDPrintString("Hello world");
// c='0';
// while(1)
// LCDSetPosition(1,10);
// for(i=0;i<100;i++)
// __delay_cycles(1000);
// LCDputch(c);
// c++;
// if(c>'9') c='0';
and it works. I have to translate this program in assembly language, you can help me? I am desperate because i try to do this program from 3 weeks and I did not succeed. I use MSP430F5437A.Thank you very much.
BB code č Attivato
[IMG] č Attivato
Il codice HTML č Disattivato
Aiuto, esercizio Arduino saw_ana Arduino 5 12-12-2012 20.24.29
Esercizio assembler MaryFrą P. in Assembler 1 19-06-2012 20.08.14
Esercizio amplificatore roby006 E. Analogica 2 31-03-2012 12.51.31
esercizio assembler dott P. in Assembler 2 10-06-2007 17.42.38
Altro esercizio assembler piccolastella P. in Assembler 3 01-06-2003 06.45.03
Tutti gli orari sono GMT. Adesso sono le: 21.02.23.
